6.4 Water in the Fuel...Is there a way to purge the system??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-07-2011, 06:44 PM Thread Starter
capitanjose's Avatar
So I filled up on the way back from Maine.... Got on the Highway in about 5 miles got the "drain water seperator" indication on the dash....
Pulled over drained it... Got on the highway in about 5 miles got it again.... Couldn't pull off for 15 min... The truck started to lope and surge.... Then died...
I drained the water seperator... But the truck would not restart...
Have since dropped the tank... polished the fuel with a marine fuel polishing system.. Changed the filters. Cleaned out both filter housings spotless... the truck will now idle but when shut off will not restart without a shot of starting fluid....
Does anyone know if there is a way to purge the system, fuel rail, injectors ect???
Not to happy about the possibilty of taking it to the dealer to have them pull off the cab to replace or check the injectors......
Suggestions????
capitanjose is offline
post #2 of 6 Old 02-10-2011, 05:53 AM
NOLA's Avatar
good luck . mine died and wouldnt restart at all. there changing all eight injectors and the high pressure fuel pump. been in the shop for 4 weeks now.
2008 F250 LARIAT 4X4 SOLD.....
ROLLIN MY 3RD 7.3 GOTTA LUV EM...SOLD>>
2008 F250 Fx4 traded in.
2010 F150 FX4. SOLD....
2000 F350 CREW CAB DUALLY. 7.3
NOLA is offline
post #3 of 6 Old 02-10-2011, 06:55 PM Thread Starter
Why so long??.... the cab apperantly comes off pretty quick.....
post #4 of 6 Old 02-11-2011, 07:09 AM
NOLA's Avatar
it stood there for 3 before they touched it, i just got off the phone with them they changed 8 injectors and the hpfp. still had 1 injector leaking. Ford made them change all eight injectors that they just replaced. Just taking way to long. Might have it back today they said.
NOLA is offline
post #5 of 6 Old 02-11-2011, 07:40 AM Thread Starter
Sucks.... Yup I have 4 bad injectors.... FORD is recommending that the whole system be replaced.... including the HPFP.. We'll see...
post #6 of 6 Old 02-11-2011, 10:03 AM
Have they covered the HPFP under the warranty? Or does the water void this?
Swank is offline
Tags
6.4 fuel issues , fuel problems , injectors , water in fuel
