EGR Sensor A circuit high 6.4 ~ Limp Mode? - Ford Powerstroke Diesel Forum
Old 01-31-2011, 05:36 PM
truck is a 08 with 96k miles,
yesterday when I was returning home, the check engine light came on and the power became sluggish, it drove smooth but took a while to get up to speed.
today I tried scanning it, and my old scanner could not link up, so I went to autozone and they scanned it, turned out to be the egr sensor a circuit high, he said it appeared twice. he cleared it, and i started driving. there was no CEL but it was still sluggish. about 15 mins later the CEL light came back on. Any idea what this code exactly means and best way to fix it? truck is 100% stock.
Only thing I can think of is the last few regens were canceled because I was almost done driving so it has not regened in a few weeks. Also, my last fill up was b5 diesel because they were out of normal diesel. Last week I also changed the batteries. Fuel filters were done a few thousand miles ago. I am not noticing any smoke.
thanks
Old 02-01-2011, 12:59 PM
anyone have any ideas?
Old 02-01-2011, 06:18 PM
Send a message via AIM to eric.davis
I got this same code a couple of weeks ago. It was my Fuel Rail Pressure sensor that went bad. Its a $34 sensor but the bad part is its located under the passenger side valve cover. After I had mine replaced CEL went away and truck was good as new.
Old 02-01-2011, 06:20 PM
thanks for the reply
was it covered under warranty, if not, do you know the labor cost? also did you drive with the cel for a while without doing any harm?
thanks
Old 02-02-2011, 12:33 PM
have a appointment tomorrow (was cancelled today because of the blizzard)
hopefully they can fix it in a day under warranty, il keep ya posted
Old 03-17-2011, 05:55 AM
I am having the same issue. Any update on the fix?
Old 03-17-2011, 09:51 AM
the dealer fixed it under warranty, they had to remove and put in a new egr sensor, of course they broke thier special tool and the sensor (seems to happen to everyone), so they had to pull some of the exhaust and drop the transmission to get to the sensor, and order some new exhaust pipe and a new sensor, all in all it took almost a week but they gave me a rental.
Old 03-17-2011, 03:49 PM
Powerstroke Techie
Feedback Score: 3 reviews
that sensor is a pain in the *** to change and the do frequently break off in the right side up-pipe. best thing to do is get it broken loose and spray it down with penetration oil then working it back and forth until it comes out. hopefully the threads stay in the pipe
Old 04-27-2013, 07:32 PM
egr sensor
egr valve was replaced and month later CEL came on and code read egr sensor so replaced it and had the codes cleared and CEL came back on and had read again and says the same thing.... any suggestion?????
Old 04-29-2013, 08:22 AM
Powerstroke Techie
Please post the code numbers if possible.
