just got my truck afew weeks ago and i love it but .....08 f350 supercrew 5" straight pipe edge programmer 37" tires sb intake 166,000km my small antfreeze res leaks abit somewhere and how the last few days i got antfreeze all over my left front inside tire and all over spring and mirror it dont leak when it sits and when it runs i cant see the leak ??? makes a big mess both jugs r not real low also yesterday on the coldest day of the year -37 truck had heat when temp was at 188 then we i got no the hwy and punched it the temp went to 192 and i lots all heat slowed rite down temp dropped and heat came back ??? also covered the hole front of the rad ?? on friday i was sitting in the truck and the idle was up everything was good the the truck would shake and rev up and down if i gave it more fuel it would smooth out then it went away yesterday morrning at cold start it did the same thing rev up and down ??? ford here will not tell u nothing and i bought the truck 26hrs away so that dealer will not help....i am a full time on diesel hwy trucks but i don not no anything about this 6.4 any help would be good thanks ryan laynlowtransport@hotmail.com
these trucks will rev up and down on cold starts to help warm it up quicker to lower emissions levels. as far as the degas bottle, is there any white residue around the cap? and do you hear a howl/moan sound on deceleration?
nothing on cap ..the rev up i no about but this is not the same ???
oh. hmm. guess id have to see it. sorry
thanks anyway
It's hard to read your post but if you have a coolant leak you should pressure test the system find the leak and bleed the air out of the coolant system.
Your radiator is leaking, its a known issue with the 6.4.
| Tags |
| 6.4 antfreeze leak |
