turbo Question
Hey guys I have a turbo leaking oil on the drain tube and I was wondering if the turbos can be seperated on the truck? I dont know what im getting into with removing both turbos.
which drain tube? I did a low pressure drain on the truck without seperating anything or pulling the exhaust. it really sucked but it got done
high pressure i don't know about, I'd pull turbos together. you're getting into a lot of work if you don't know whats going on |
Its the none vgt turbo im going to say high side. I can pull them both I just really dont want to pull both but if I have to I will
You have to pull them both at the same time, and the non vgt turbo is the low pressure turbo.
ok thanks Ill see what I get into then. thanks for your help
