Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-11-2010, 07:06 AM Thread Starter
Oil Leak
Started to notice a half dollar size patch of oil on the ground under the oil pan. I had a local mechanic shop take a look at it and was told that it was the oil cooler for the turbo. I'm going to take my truck to the dealership as I still have extended warranty remaining. Is this a difficult repair and what damage could I do driving the truck over the weekend? Where does this cooler draw its oil from? A separate oil reservoir? Is it easy to fill? I need to use the truck over the weekend but I don't want to cause any long term damage.
2015 F250 Lariat SD FX4
6" Rough Country Lift
20" XD Series Wheels
37" Nitto Trail Grapler M/T
Stock
2008 F250 Super Duty 4X4
6" Pro Comp Lift
Pro Comp 6001 Wheels
Nitto 37" Terra Graplers
4" dpf/cat delete w/MBRP
SCT Tuner - Performance Tune
bsudkamp is offline
post #2 of 10 Old 11-21-2010, 05:26 PM
Hey bsudkamp - what did you find out? I have an 08, 6.4L and when changing the oil yesterday, I noticed some oil leaking on the frame member in front of the oil pan. Where did you see the oil leaking on your truck? Did Ford cover it?
Beech is offline
post #3 of 10 Old 11-21-2010, 07:08 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
beech i've seen both oil pump housings and front main seals leaking on the 6.4, also the cam sensor orings will wear out. as for the OP a leak in the valley can be a little harder to diagnose, cant really say where it's coming from without looking at it
i would think ford should cover any engine oil leaks under 5/100,000. i haven't had any instances where they didn't
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 10 Old 11-25-2010, 09:32 AM Thread Starter
Oil Leak
So for the dealer has found a cracked dip stick tube and replaced it. Will know more in a few days.
Stock
6" Pro Comp Lift
bsudkamp is offline
post #5 of 10 Old 11-25-2010, 05:36 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
haha seen that before too. not exactly in the same spot as the oil cooler housing
the tubes break right at the bracket and crankcase pressure pushes oil up and out
-Matt
2015 F-250 XLT 6.7L
post #6 of 10 Old 12-03-2010, 03:40 PM
Mine was a leaking crankshaft seal. Fixed under warranty. Job 2 truck, 27K mi.
Beech is offline
post #7 of 10 Old 02-21-2011, 07:10 PM
Duffie112's Avatar
Send a message via AIM to Duffie112
i notices a wet spot on the frame right next to the passenger side shock hardly enough to drip, where could it be coming from?
Cory Duffie
2012 F-350 CC 6.7L
H&S
Incubus
AFE
Flo Pro
Duffie112 is offline
post #8 of 10 Old 02-25-2011, 07:35 PM
Beech, I was looking under my truck today and noticed an oil leak coming from what apears to be the crankshaft seal. How long did it take the dealership to replace it? I have an appointment on monday with the dealership. It really sucks because I only have 4500 miles on my truck.
rgonzales39355 is offline
post #9 of 10 Old 02-26-2011, 01:44 PM
The front main seal was replaced quickly. I asked the dealer to check some other items also when they had the truck, so I am not sure about just the seal, but I would say half a day.
Beech is offline
post #10 of 10 Old 02-26-2011, 01:56 PM
Ok cool thanks.
