degras level - Ford Powerstroke Diesel Forum
Old 10-20-2010, 08:44 AM
degras level
What will happen if the coolant level in the degras bottle droped below the lower outlet.
Old 10-21-2010, 09:11 AM
Nothing. Air bleeds off the cooling system when you open the cap. Just refill it and start worrying why it's so low.
Old 10-22-2010, 03:25 AM
It was low because it was in for a radiator replacement, and the mechanix didn't road test it after he filled the resevior, so when i drove it home poped the hood, noticed it was below the outlet.
Old 10-22-2010, 12:12 PM
So you got me thinking,crawled underneath the truck and started looking,there is some residew by the front axle look-up by where the the heater core is an i see 2, 1/4 inch hard lines an a 3/8 rubber one with a clap below the 2 hard lines,sticking out of the fire wall by an inch with nothing in it.What do you think that could be.
Old 10-22-2010, 12:20 PM
Prolly not good!
Old 10-22-2010, 02:32 PM
Sounds to me like its the A/C condenser drain. The condenser is in the cab under the dash and it creates quite a bit of moisture when the A/C is on and it has to get out through that tube.
