slight coolant loss - Ford Powerstroke Diesel Forum
Old 10-18-2010, 04:45 AM
slight coolant loss
have an 09 f350 with 14k. since my last oil change 6 months ago i have been keeping an eye on the level of coolant in the reservoir. at the beginning of the summer it was at the level at the bottom of "range", now when i checked it on level ground it is slightly below. I have not noticed any leaks since due to paranoia i look under the truck frequently.
is this normal and or something i need to be worried about?
i`m going in for an oil change soon, so I want to be prepared just in case i get "its completely normal" speech.
Old 10-22-2010, 03:31 AM
Just wait, that same thing was happening to me, next thing you know the radiator had a small drip on the driverside bottom you could see visiable residew on the frame rail.
Old 10-22-2010, 04:42 AM
checked it yesterday and it was back up to range again, strange.
Old 10-22-2010, 10:03 AM
And then what?
Old 10-22-2010, 10:14 AM
Originally Posted by itn69 View Post
And then what?
Took it to the dealer to have it replaced under warranty,alond with the upper hose and tee stats.
Old 10-22-2010, 12:23 PM
taking mine in to have it looked at for the same reason...mine has gone down about an inch over about 5k miles or so.
Old 10-23-2010, 09:18 PM
Mine changes 1"-2" depending on coolant temperature, and raises when you unscrew the cap (after shut down) and let the pressure off.
Old 10-24-2010, 02:09 AM
i checked mine today and its slightly low again, guess its as you stated.
Old 10-25-2010, 05:41 AM
is it part of the motor warranty?
Old 10-26-2010, 04:57 PM
Mine was low the other day, noticed a lil on the bottom....dealer pressure tested and said upper was leaking as well. Replaced upper and lower.
