crank, no start im a tech ready to pull body
chime in if you are a technician or very well versed in the 6.4. we have a crank no start condition and starting to pull body now, dont have a cause yet but best guess is injectors and there is only one way to get to them for testing
What is your fuel rail pressure? You can get to the injectors by removing the valve covers cab on.
Any codes? Alot of things show up on the ids that don't on a generic scan tool.
rail pressure of about 6000 psi cranking
we are using the ids, was able to do a buzz test and all responded so its not injector electrical basically at this point we have the body off, have replaced the injectors, the dpf, and turbo (it had a cracked housing, wouldnt cause our no-start but needed repair none the less) |
