No more white smoke !!!!!
If it wont start it can't smoke. Doesn't turn over. Headlights and dash lights come on, ac motor blows, but won't turn over. Ford thinks every one that brings there truck in is a moron. You tell them your blowing white smoke like a steam engine and they say it was in regen and nothing is wrong. If they don't know how to fix it or don't want to pay to fix it, Ford gives you some crappy excuse and hopes you accept it. Come on Ford get your **** straight.
If an EGT sensor went bad, it could cause a no start problem. If you set the key to the run position, pop the hood, there is a wire by the passenger battery that feeds the starter. Disconnect the round connector behind the passenger battery and jump it to the positive post and the truck will start. It will not start again with the key until the egt problem is fixed.
Does it sound like it's locked down?? Does it make a "clunk" sound like it's trying to turn over but it's locked down?
No its not locked up. Starters not trying to engage. Some sensor has it shut down.
