'10 f550 burn 2 quarts a week
Truck has 14k miles(bought new). Spartan set to 210hp dpf delete havin to add 2 quarts of oil a week. No blue/white smoke, no errors codes, no leaks etc. Any help or intel before I put dpf back on and go to dealership
What kind of oil are you using?
Delo 400 15-40 LE
I run it in my dmax and 7.3L powerstroke with no problems
No leaks at all?? Maybe a bad turbo seal or something. You could take off an intercooler boot and inspect for excessive oil contamination. Just an idea.
No leaks!!!! I inspected the **** out of it
Notice any heavy smoke coming from the tailpipe when it's running?
Only black when I stomp on it...
Sorry man, I'm out... if you've checked everything under the hood, and there's no leaks, and no white smoke to signal burning oil...then your guess is as good as mine. Sorry bud. Sounds like a badass truck other than the oil dilemma. Hopefully some of the gearheads on here will notice and help out. Oh well, free bump for you. Good luck!
I know this is terrible timing to ask, but you should post some pics of your beast up here. You don't see many 2010 F-550s around. |
K check back in bout two hrs. I just snapped a few. When I'm home I'll upload. Also search my past post I took a few pics after I bought it and got bed on
John |
