Coolant Leak Drivers Side?? - Ford Powerstroke Diesel Forum
Old 09-22-2010, 06:15 AM
I have a small coolant leak comong from the drivers side of the vehicle, it is dripping down by the front axle....i cant find exactly where it is coming from....any suggestions?!?!
Old 09-22-2010, 05:59 PM
either upper coolant hose or cracked radiator
Old 10-07-2010, 08:18 PM
had the same problem on mine.. 08 f350 upper rad hose O ring on engine side.. you need to replace the O ring, $5 part, and need to make sure you clean the aluminum housing really well before re-installing
Old 10-08-2010, 04:55 PM
Send a message via Yahoo to Sidewinder007 Send a message via Skype™ to Sidewinder007
The O ring problem sounds good to me. My problem ended up being the cracked radiator...
Old 10-08-2010, 05:10 PM
mine is leaking at the oring right now,it going in the shop tues, is this covered by the powertrain,100,000 mile warranty?
Old 10-11-2010, 07:24 AM
Dealer just fixed my leak Friday it was the O-ring. Still waiting for them to fix the rest of the truck.
Old 10-22-2010, 03:35 AM
Mine had a cracked radiator,drivers side, so the replaced the radiator,upper hose, and thermostats.
Old 11-11-2010, 07:34 PM
Mine had a leak too. Turned out where the hose clips on down by the axle let go, i put it back in place and leak stopped
Old 11-12-2010, 01:32 PM
I think the radiator hose O-ring is a cab off job?
Kidding!
Old 11-16-2010, 05:17 PM
Dumb question but if you are modded (DPF delete, Spartan, etc...) will they cover the radiator? Or should I just go through the hassle of returning to stock. 3yr / 36k is expired.
-Or- is the O-ring thing a DIY job? I am decently handy....
