Need new Radiator but no Code showing for Warranty - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-16-2010, 06:28 AM Thread Starter
SoonerDS's Avatar
Hey fellas,
Here is my prob. My Radiator is leaking like crazy @ 73,000 miles and I called the Dealership to have it replaced under warranty. Previous to me knowing that I had a leak, I had my check engine lite come on so I retrieved the codes and cleared them with my tuner. The code that I cleared was for the Thermostat but I don't remember the #.
That's where the prob starts. The dealership said that the radiator recall falls under the 3 yr/36k warranty and that for me to have my radiator replaced now it would have to show codes for faulty thermostat.
I would think a recall wouldn't have to be done within any certain time frame but I'm no expert and the code for the thermostat hasn't ever reappeared.
Is there a little trick I can do to force it to trip that code again???
Thanks in advance
SoonerDS is offline
post #2 of 14 Old 09-18-2010, 06:56 PM Thread Starter
SoonerDS's Avatar
no help here???
SoonerDS is offline
post #3 of 14 Old 09-18-2010, 07:15 PM
dieselkane's Avatar
Codes for a thermostat?? I didn't think codes popped up for a bad thermostat. The TSB outlines a specific test in order to check for faulty thermostats. It requires driving the truck, and monitoring EOT and ECT.
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #4 of 14 Old 09-18-2010, 07:23 PM Thread Starter
SoonerDS's Avatar
thanks for the response, I've seen the TSB, but I've also seen the code with my own eyes so I know the dealership wasn't bs'n me. Just wish I hadn't cleared it lol. I'm guessing there is a sensor in the thermostat housing but not really sure.
SoonerDS is offline
post #5 of 14 Old 09-18-2010, 07:32 PM
Powerstroke Techie
forddieseldoctor's Avatar
Yes there is codes for bad thermostats. It is P0128 - Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
Description: Indicates that the thermostat monitor has not achieved the required engine operating
temperature within a specified amount of time after starting the engine.
Possible Causes: Insufficient warm up time
Low engine coolant level
Leaking or stuck-open thermostat
Inoperative engine coolant temperature (ECT) sensor
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #6 of 14 Old 09-18-2010, 08:01 PM Thread Starter
SoonerDS's Avatar
Question
That would be the one....do you know how I could force that code again without damaging my engine
SoonerDS is offline
post #7 of 14 Old 09-18-2010, 10:07 PM
dieselkane's Avatar
Oh ok. So does this code typically appear on 6.4 engines when the thermostats have failed? Or does the code not always show up like it should when there is a problem?
post #8 of 14 Old 09-18-2010, 11:48 PM
shhhhh, can you hear it?
08pwrstrokr6.4's Avatar
looks like you could drop the coolant level and make it arise but how much coolant i dont know and it would be beneficial to know how long it has to be on for the light to trigger.
Patrick
TAPS Historian
08 6.4L ECSB
S&B intake,H&S Black Maxx,5" Pipe,Trac. Bars
13.77@100.63
OIF 07-08 16 months OIF 10/OND 10-11
Originally Posted by Diesel Tech Mag
All you need is a little knowledge,the right tools, and a buddy's truck to practice on.
08pwrstrokr6.4 is offline
post #9 of 14 Old 09-19-2010, 12:01 AM Thread Starter
SoonerDS's Avatar
i thought that would work too, but with the radiator leaking as bad as it is, that has been tested already. I've driven close to an hour with the temp running between 210 - 230 deg on more than one occasion simply because I'm friggin tired of pulling over to refill it.
I wonder if I unplug the ECT sensor if it will trip the code
SoonerDS is offline
post #10 of 14 Old 09-19-2010, 08:50 AM
Powerstroke Techie
The only time the code shows up is if the ect sensor temp does not rise a certain number of degrees in a certain amount of times. Such as a stuck open thermostat. If you unplug the ect sensor it will simply throw a code for ect sensor circuit fault. I don't have a good way to tell you to get the code to reappear without risking damaging the motor.
Meet Double Aught
2000 F250
