P0088 Help me - Ford Powerstroke Diesel Forum
Old 09-04-2010, 09:12 AM
P0088 Help me
Well my truck has been acting up on me these past few weeks while towing with the 210 heavy tow tune. it will run fine then if u let off then start pushing it again it will start missin like crazy an throw the P0088 code. I can start it in the mornin and drive about 20 miles get a load and come back the other 20 an it drives fine i shut it off and eat lunch then when i start it back up and take off again it does it ..i can clear the code and the truck runs fine it has done this exact same thing for 4 straight days. I took it to the dealer and he put new fuel filters in it but that seems to have not worked. Any ideas guys
Thanks a lot
Adam
Old 09-04-2010, 09:45 AM
That code seems to show up when you either have bad fuel or high exterior temps... IIRC spartan revised the tune to prevent that code from triggering.
Old 09-04-2010, 12:39 PM
Powerstroke Techie
Is it an early build truck?
Old 09-05-2010, 07:44 AM
yes it is a job 1 and i have the most updated spartan tunes i have been running that tune for probably 5 months
Old 09-05-2010, 08:56 AM
i got the same issue when its hot outside,,if im towing and its over 90 it triggers the code , mines a job 2
Old 09-06-2010, 03:57 PM
Does this PO0088 code have to do with excessive high fuel pressure....I had a problem at 117,000 miles. This code might have to do with excessive high fuel pressure, I had to have the the high pressure fuel pump replaced by the dealer, cost to me 0 dollars...because of my 21 major engine componets warranty. This had nothing to do with bad fuel or fuel filters, I was told by the diesel tech ...this was expected because of the high pressure fuel pump design. My truck is still stock so I had no issues with the warranty....cost to Ford was $ 3100.00
Old 09-16-2010, 01:08 PM
Anybody else have any ideas
I sure hope it isnt the HPFP im wantin a suncoast and if this is the problem there goes that out the window
