turbo problems
truck making a lot of noise like an exhaust leak by the turbos.. and when you put a heavy load on it i get exhaust gas and smoke from around the turbos.. and along with that i am getting a berring grind coming out of the turbos.. i think i over boosted it and let off the throttle to fast and the back pressure cracked the casing... if i can get ford to worrenty it i am going to get a blow off valve and put it in as soon as i can.. what do you guys think else could be the problem and has anyone put a blow off valve in yet...
exhaust leak
You should have them check your hoses to your turbo there is part of the hose that has a crack in it and is sucking air into it. They will have to pull the cab off to fix this problem. Thank You. Frankie
