Lots of smoke and loss of power - Ford Powerstroke Diesel Forum
Old 08-19-2010, 05:58 AM
I was taking off from a stop light the other day. Started going fine then all of a sudden the power cut back significantly and I looked in the mirror and I was blowing lots of white smoke out of the exhaust. Let up and accelerated twice before it went back to full power. Was not in regen. when this happened. I did have it blow a ton of smoke one other time when in regen mode and i had to accellerate a little harder. Any thoughts before I bring it in?
Old 08-19-2010, 08:38 AM
mine does it to the dealer says its from my tailpipe aha, but only when that happens i lose coolent keep an eye on your coolant and see if its low
Old 08-21-2010, 06:19 PM
sounds like head gasget problem generaly white smoke out the exhaust is a sure sign
Old 08-22-2010, 06:45 AM
Powerstroke Techie
Not on a Powerstroke.
OP: Any codes?
Old 08-23-2010, 07:41 PM
Mine was the intercoolers and egr valves and cracked egr housing they kept my truck 2 weeks 7000 miles later back in shop today loss of power check engine light code p1335 egr prolems again good luck ford needs to do a total recall of all these trucks and put the new 6.7 in them if they are so great that's the only way they will get my business again
Old 08-23-2010, 07:46 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
what kind of truck
Old 08-24-2010, 07:29 PM
the 6.7s are junk to, they have some kind of viscosity tester for the oil pan if the oil is not up to par it shuts the truck off, amazing what these electronics are going to cost to fix when the warrantys up plus the 6.7 really hasnt been around too long so you really dont no the hidden issues yet, not to stick up for the 6.4 but they have been around for quite sometime just not in trucks (tractors) so ford gets ahold of it puts a couple of tiny turbos on it-egr valve, and a tampon in its *** what do you expect them to run like just my 2 cents
Old 08-25-2010, 04:16 PM
Powerstroke Techie
Where'd you pick this gem of information up from, might I ask?
As for your two cents....
Here's your change.
