Check Engine Light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-17-2010, 05:49 AM Thread Starter
Check Engine Light
This morning at 5 am truck kicked the cel under normal conditions no load just driving and threw these codes.
P20E4 - Exhaust Gas temp sensor 2/3 correlation bank 1
P242b - Exhaust Gas Temp sensor bank 1 sensor 3 circuit rang / proformance
P117B - Exhaust Gas Temp sensor bank 1 correlation
What does this mean and is the truck drivable with out causing more problems? Cant get it in to ford right away.
2008 crew cab 4x4 6.4 with 35000 miles.
JB904 is offline
post #2 of 3 Old 08-19-2010, 08:53 PM
Powerstroke Techie
Sounds like your 3rd EGT sensor is going for a poop. There's a thread in here somewhere about EGT13. I'd print those directions out, if it takes a dump on you, there's a good possibility that the truck won't crank or start, and this could leave you on the side of the road at 5am the next time it happens.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 08-21-2010, 06:24 PM Thread Starter
Thanks for the reply its at ford now getting sensor replaced
JB904 is offline
