6.4 l oil overheating - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-08-2010, 08:23 PM Thread Starter
2008 6.4l with 60000mi, after driving for 15 mins I get a decreased engine power message and the engine temp guage spikes to max. Engine coolant temperature stays normal(200 deg approx), but engine oil temp increases to 260+. Ford dealer replaced engine oil cooler, thermostats,coolant and oil temp senders, water pump and front cover under warranty, but problem still persists. Thinking there is a coolant restriction somewhere going to the oil cooler, but not sure...any ideas?
grabowskimech is offline
post #2 of 5 Old 07-09-2010, 12:16 PM
Sounds like a bad oil cooler thermostat to me if it overheats that quckly and your coolant is normal temperature.
BlueF350 is offline
post #3 of 5 Old 11-08-2010, 09:23 PM Thread Starter
okay...dealer has replaced engine oil cooler 4 times(believe it or not) and just put in a new short block engine and oil still is running at 250- 260 degrees and coolant at 210...the only thing I can see is the turbo maybe running hot but that doesn't even make sense...any ideas cause i'm getting tired of taking this truck in and not getting it fixed, although the free shortblock engine was sure nice.
post #4 of 5 Old 11-08-2010, 09:37 PM
dieselkane's Avatar
Possibly the EOT sensor, or if the radiator wasn't replaced maybe it is clogged
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #5 of 5 Old 11-12-2014, 03:37 AM
oil overheat
i have the same problem ,did you salve the problem, let me know
yiannis50 is offline
