Engine/exhaust noise - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-27-2010, 01:26 PM Thread Starter
I have a 2008 F450 6.4 powerstroke, with approx 45000 miles, that has developed a fairly loud intake or exhaust noise over the last 3 or 4000 miles. It is loudest when accellerating or pulling up hills. It sounds like loud exhaust on a gas engine, or the sound a carburated engine makes with the intake filter housing removed. It does not matter whether the engine is cold or hot. It is becoming progressivly worse. Any ideas?
heliostol is offline
post #2 of 11 Old 06-27-2010, 01:36 PM
Powerstroke Techie
Exhaust up-pipe leaking from the manifold to the turbocharger, perhaps?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 11 Old 06-29-2010, 04:25 PM
sounds like the up pipe
First_Ford is offline
post #4 of 11 Old 07-12-2010, 10:06 PM
From under your truck, look at the front of the tranny, and up the firewall at the back of your engine. Is there a layer of soot all over everything?
murrjck is offline
post #5 of 11 Old 07-13-2010, 01:38 PM Thread Starter
exhaust leak
Thanks for your reply.
After reading your question, I got under the truck with a good light and an inspection mirror this morning and finally found some soot. It is not easy to see, but it apears that the flexable connector is leaking on the passenger side exhaust riser,between the exhaust manifold and the turbo inlet piping.
Looks like I will need to remove lots of parts to get to the leak for repair.
Have you had experience with this?
Thanks,
John
post #6 of 11 Old 07-28-2010, 10:49 PM
Yes and no. I described my truck to you cause my truck fit your description about 5k miles ago. I have been trying to learn more about it and ways to prevent it from happening again AND figuring what else should be done while truck is down for repairs. I have no warranty so I have to research everytghing thoroughly to minimized truck downtime. If you have warranty, just go get uppipes replaced. new Ford uppies will fail sooner or later and I have rulled out. to me it's unacceptable. I saw an EGR delete kit that comes with solid sturdy uppipe but it was for 6.0. Waiting on a response from manufacturer about 6.4. I think this will be my route, if you're interested let me know, maybe we can get discount on multiple or even group buy!
murrjck is offline
post #7 of 11 Old 07-29-2010, 02:55 PM
mattyl's Avatar
Send a message via Skype™ to mattyl
have not had this problem yet but there is a egr delete kit that rudy's sells i believe and it should come with solid up pipes
08 F350 XLT DRW, Spartan 250 tune, 4" open down pipe back, Navi radio, Cold air intake, Dash Daqxl monitor, 2800 watt custom sterio 2-10" subs all new 5x7's, back up camera , hid hi low set up just installed..
mattyl is offline
post #8 of 11 Old 07-29-2010, 07:27 PM Thread Starter
I just got it back from the dealer.
They replaced the up pipe on the passenger side. It is difficult Job.
They had to drop the transmisson to make the repair.
The invoice was near $1200.00 and my cost was $100.00.
Thanks for your advise.
John
post #9 of 11 Old 06-03-2011, 07:46 AM
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
So did the new up pipe solve the noise issue?
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #10 of 11 Old 06-03-2011, 04:15 PM Thread Starter
Yes the up pipe solved the problem.
