6.4 High Boost / Low Power Issue - Ford Powerstroke Diesel Forum
Old 05-23-2010, 04:44 AM
I have a 2008 F-550 That we just installed a new engine. We installed a DPF delete package, EGR block off and SCT Live Wire tuner at the time of engine replacement. When you start up the road at 1/2 throttle, it will make up to 59 psi of boost (regardless of tune). It seems that once the truck gets to 55 mph the boost drops and the truck runs OK. At that point, full throttle we are getting about 41 psi of boost. If you stop and cycle the ignition key, it will go back to high boost. Only item I noticed is the EGR block off plate is installed on the top exhaust flange. I think it should be installed at the cooler on the left side (drivers) of the engine. We have blew (3) CAC hoses.
Old 05-23-2010, 11:10 AM
Make sure the actuator for the turbo is moving freely, if it binds the boost will do funny things.
Old 05-23-2010, 11:23 AM
shhhhh, can you hear it?
might wanna put on a waste gate
Old 05-23-2010, 01:16 PM
I think the EBP sensor is located right before the 1st EGR manifold. If so, the way we installed our block off plates the EBP would sense 0psi. Could this cause the problem?
Old 05-23-2010, 02:19 PM
bump bump bump
Old 05-24-2010, 02:27 AM
I missed that in the first post, yes the plate should be by the cooler. The EP sensor is not reading anything and spooling up the turbo hard. I'm not really a fan of the block off plates, I prefer the EGR delete with wastegate, it helps relieve the drive pressure.
Old 05-24-2010, 09:37 AM
Relocated the block off plate and that took care of the issue.
thanks
Old 05-24-2010, 03:25 PM
good to see you up and running.
Old 03-28-2011, 11:56 PM
low power issue
Wow that's good news. I also don't know that the block off plate is the problem in that case. I thought you have to fix the exhaust pipe flanges.
