Tearin in to the motor - Ford Powerstroke Diesel Forum
Old 04-18-2010, 06:32 PM
Well, the time has came. Ive delt with the engine knocking/ticking for a few months now and Im tired of wondering whats wrong with it and if its major or not. So my trusted mechanic is gonna pull the cab and start lookin for the problem. He thinks its the piston skirt or wrist pin. The motor doesnt tick/knock until its warmed up to 180 degrees and there is no power loss. Doesnt blow smoke or nothing. the mechanic hooked up his computer to it and shut down each cylinder seperate and ruled out injectors. Then my trusted mechanic pulled the oil filter and discovered aluminum shavings in it. So thats when I decided to have him tear in to it....do you guys have any input on this? Am I doing the right thing? He said Ill have around 1000-1500 bucks for parts and labor after everything is said, done and fixed......thanks in advance for the input!!
Old 04-18-2010, 06:49 PM
The 1000-1500 bucks sounds low, but he may by doing you a favor. Post some pics of the filter, sounds like you have no other option. Good luck, PICS.
Old 04-19-2010, 02:36 AM
That's real cheap. If he sticks to that price, he's doing a big favor. I think I go through $500 just in gaskets and fluids on a tear down.
Old 04-19-2010, 07:26 PM
Ill see if I can get some pics of the shavings
Yeah, He will stick to it. He said no more then 1500. but am I doing the right thing? or should I just find another used 6.4 and sell mine? he plans on doin it in a few weeks. and if I do go ahead with the tear down, is there anything else I should modify while the motor is torn apart? like head studs? cam? forged pistons?
Old 04-19-2010, 07:28 PM
is this in your 08?
Old 04-20-2010, 02:16 AM
Minimum of studs. Anything else you want to upgrade, this is the time to do it. Let us know if we can help with any parts.
Old 04-20-2010, 06:05 PM
Originally Posted by choupique108 View Post
is this in your 08?
yeah it is...well the festiva ticks too but im not to worried about that one
whats studs run? and I dont know what else to do if anything. has anyone tore down a 6.4 and put upgraded parts in it? I want the truck to be reliable. I plan on putting the spartan 310 in it as well. But I dont have a clue about what kind of internal parts to go with, if any....Thanks!
Old 04-21-2010, 02:26 AM
Give us a call at (866)757-6537 or (919)636-1518 and we can walk you through any questions you may have. I build these engines every day and would be glad to help you decide what's best for you.
Old 04-21-2010, 05:19 PM
Ok, Ill give you a call tomorrow. Thanks!
Old 04-21-2010, 06:03 PM
Do you not have a warranty?
