Well the radiator gremlin finally caught up to me...
Just bought an '08 with 50K on the clock two weeks ago. Wife called to tell me as she was leaving the house, there was a pool under the front. Sure enough it's coolant, but can't see where it is leaking from as it appears it dripping out of the fan shroud, but running all over the underside. Could it be a water pump? With all known issues, guessing it's the radiator and thinking about towing it in as there is now a nice trickle of water flowing on my curbs. I take it this isn't a covered power train warranty issue? Worth an attempted drive to the dealer or just call a flat bed early in the morning?
I'd tow it. Some were able to convince their dealers to do it under the engine warranty because it's a known problem. Good luck
Yeah, I'm going to have it towed back to the same dealer and hopefully...they'll do the right thing...so is there some kind of special tow rig I request to tow this mamouth? It's got a 6" lift and 35's...I just don't want to wait an hour to have them show up and say, "oh, we need to call for another truck."
Dudel i Just found this for you, hope it helps you sleep better!!!
kylebryan Powerstroke.org Rookie kylebryans Gallery Hall Join Date: Dec 2009 Posts: 9 Ford has extended the warranty on the radiators on these trucks. Heres a thread on FTE All 6.4 Radiators are now covered for 5yr/100000 miles - Ford Truck Enthusiasts Forums Mine started leaking at 43k. My thermostat locked up on a muddy back road one day and blew the coolant line off the passenger side of the truck that goes into the engine. Needless to say it puked out all my fluid in about 2 seconds and i never even knew it was happening untill the temp light came on. Its a well known problem about these truck to have coolant issues and its a good idea to walk around once a week and look for leaking coolant. Id hate for you to have to buy 70$ worth of coolant like i had to. (Its expensive from a conveinence store in the middle of nowhere!) Anyways since ford knows its an issue take it in ASAP. __________________ |
Radiators:
At this point, they are covered to 100k if the thermostat is found to be the failed component that has caused the radiator to leak. If the thermostat functions normally, the radiator coverage is bound to 3/36 or 3/60k if you live in Canada. |
Well, the bad...new radiator, new water pump, and new fan clutch...the good, they covered it all under the warranty (though they made mention the used car dept paid the $100 deductible). In any event, the beast is back up and running w/o any additional costs. I would hate to see that bill, I'm guessing $1500 easily....
Glad they covered it, but don't let them fool you. There is NO deductible on '08 and up, if you ever need more warranty work.
