3 dealers no solution Need serious help.!!
So it's my boss's truck. 2008 f350 king ranch 4x4., 6.4 l of course.
Here is the problem. Truck runs and drives perfect. Let it idle for a minute or two and it starts shaking bad. Shut it off and restart it and it runs fine. Doesn;'t do it every time either. Very random. Only codes are bal/cont #1 and #2 and random misfire codes. Now the first dealer charged him 300 dollars and told him nothing wrong with truck. Change your filters. So he did. Same problem. Second dealer charged him 1600.00 dollars and replaced injector #1. He went to pick up truck and it runs so rough it won;t even move. Same dealer charges another 1000.00 and replaces injector #2. Truck still has same problem. Dealer won;t help to fix it. Says pay more money and we'll look again. Third dealer charges 400.00 and says it needs 2 injectors. #1 and #2. Boss says no it doesn;t they were just changed at dealer #2. So service manager says i'll call you back. He calls back and says motor is blown. He can replace it for 24000.00. Boss says how come it's only blown sometimes and runs perfect other times? Also asked him why he first said it needed 2 injectors. Needless to say the service guy got upset and said nothing he can do. Now has anyone had a problem similar to this and know what the problem is. One of the dealers had some sort of graph running when the truck would idle rough and it showed #2 dropping out. Restart truck and it's fine. Sorry for long post but he needs help bad. |
How many miles and has ALL the maintenance been done on it regularly?
Also, get a hold of Big Angry Hillbilly on the forums here.
Regular maintenance always done. Truck has 109000 miles on it. Who is Big Angry Hillbilly?
Suscribed and bump.
A service tech up in Canada for Ford. Maybe has a better insight as to your situation and if you have a leg to stand on.
I had a similar problem on one of my cars but I dunno how it would translate over to a diesel. I had faulty coil packs and it would do the same exact thing. Run fine for a few mins and then idle like it was misfiring and go into limp mode.
I guess whatever supplies the glow plugs could be shot or even the glow plugs themselves. But thats just all guessing from my end since I am new to these trucks. |
im not sure about your issue but heres a free bump |
![]() OK. I'm in heeeeeaaaaaaaaaar. Now. I need the VIN off this rig. Off the top of my head, sounds like we've got a combustion gas in the fuel system issue, but that kinda is confusing as to why it comes and goes. Where's the truck located? |
Truck is in sask. here is the vin
1FTWW31R58EB64785 Thanks alot. |
