6.4l White smoke and won't go - Ford Powerstroke Diesel Forum
Old 02-15-2010, 01:20 PM
I have a 08 f350 with sct tuner dpf delete. Acouple of weeks ago my CEL light came on and the truck would not go and it just billowed white smoke. It finally stopped smoking and ran. This has happened several times now. You can put it in nuetral and rev the motor and it will finally stop. And run normal. here are the codes P0404 P1335 P2291 P042E P1000 U0100. I know that most are egr codes. I am just wondering If I can put the egr delete plates on and it fix the problem. My tuner has the egr delete option.
Any Ideas welcomed.
Jason
Old 02-15-2010, 01:30 PM
Any Ideas welcomed.
Jason
You need to find my thread on the garage.... I've had same problem and whole story is on there. I didn't get any of the Pcodes you've got, but someone just recently got those... SCT is SUPPOSEDLY working on a fix, but I've seen no proof, or heard anything from them in a while... RCD or Innovative tunes may be a good solution, all the other tunes in the tuner work on mine perfect but the Extreme does weirrrrrd stufff......
