Strange ticking from left side. - Ford Powerstroke Diesel Forum
Old 01-28-2010, 09:26 AM
Hey guys,
I have a ticking or grinding noise coming from the engine, it seems to be coming from the left side near the air filter and you can hear it over the normal diesel engine sound. Its pretty loud when its idling but not sure what its like while in motion. I did a search and came across this thread 6.4 in the shop with motor noise
but I am not sure the answer is there. I am kind of scared to bring it to my dealer because I have the DPF and Tuner and CAI installed. They will probably try to F me over with warranty work. Any help would be greatly appreciated!
Thanks!
Old 01-28-2010, 04:55 PM
I have added a sound clip to this, you can hear the diesel sound but you can also hear the grinding sound too.. http://brendanlush.com/images/noise2.mpeg
Old 01-28-2010, 05:14 PM
<<< 6.4 Powersmoke
I couldn't tell a thing from that clip Too short.
Old 01-28-2010, 05:16 PM
Should I upload a longer one?
Old 01-28-2010, 05:51 PM
<<< 6.4 Powersmoke
Might help
Old 01-28-2010, 06:18 PM
Alright here is a 2min clip of what I am talking about.. It kind of sounds like the fan but not 100% sure. http://www.brendanlush.com/images/noise.mpeg
Old 01-28-2010, 06:21 PM
<<< 6.4 Powersmoke
It is only 1 second long for me still
Old 01-28-2010, 06:29 PM
Damn.. I will upload it to YouTube.. http://www.youtube.com/watch?v=JI9hS_c3BhI
Old 01-29-2010, 07:46 AM
So I was chatting to a HD Diesel mechanic at my work and he said it sounds like a bad bearing or it could be a pulley. It goes in Tuesday to get looked at. Should I remove my Tuner and DPF just to be safe?
Old 01-31-2010, 06:21 AM
I have a 2008 F550 with 84500 miles on it. My noise started out as a "tick", this tick seems to be a problem for alot of people. I found that it was comming second hole on the right bank. I then pulled a oil sample and it came back high on iron. I talked to Ford and they did nothing. The tick went away about as fast as it came. Now after about 10000 miles I now hear a popping noise coming from the aircleaner. This noise I know well. I pulled the oil filter and cut it open and found iron. I now Know the camshaft has a bad exhaust lobe. Iam not a@# but i had it figured out after i heard the poping coming from the air cleaner, and it took Ford a week. So my point is if you have heard a tick or a poping noise. Pull your filter and cut it apart. Iam sorry to say you will not like what you find.
