6.4 cam gear/high pressure fuel pump gear stripped
I am working on a 2008 6.4 Ford diesel engine where the cam gear and high pressure fuel pump gear became misaligned. This resulted in the gears grinding, sending metal shavings in the engine, and bent pushrods. Ford says fuel contamination caused the fuel pump to lock up forcing the pressed on cam gear to seperate. However, the gear on the high pressure fuel pump will still turn, it does not appear to be seized. Has any one heard of the cam gear "sliding off" the cam on its own? Or, will the fuel pump "lock up" but, can later be turned?
The added factor of heat may have contributed to the seizure of the pump.
Is the bolt in the back of the pump tight? Man that's scary. How much of that crap went through the oil pump? I'd bet that motor is junk. |
Yes, metal shavings went through the engine so not a good thing. You can turn the pump gear by hand so it doesn't appear seized now.
2009 Ford Diesel high Pressure fuel pump junk 20480 miles ford denies claim
I own a 2009 Ford F350 4x4 Super Duty 6.4 Diesel. this is the truck they show in commericials pulling down houses. well let me tell you fellow ford fans this truck can't pull my 300 pound *** right now! I was driving this vehicle as a personal vehicle and truck started to lack power. I pulled into a parking lot had the truck towed to my regular garage figured it was a fuel filter. I had them replaced and still same problem. I have this vehicle towed to my local ford dealer where they want to charge me out of pocket 4750 dollars to determain if this vehicle would be covered under ford warranty ( Truck has 20k Miles ) The ford dealer tells me that they have been in contact with ford and they feel it was lack of maintance and would not cover this to determain if it would be covered under warranty however they did no it was the high pressure fuel pump. Ford Says well there are no metal shavings in the filters only in the lines so " I MUST HAVE NOT MAINTAINED THIS VEHICLE " Well guess what I have all my slips since new. Also Ford Does not require you to change the fuel filters under normal conditions until 20k So how could this be my fault? It can't be and is not. I have this vehicle towed to my local repair shop where they are repairing this vehicle. Come to find out Ford has 391 Parts orders for these fuel pumps and accessories ON BACK ORDER. So I guess this isn't the first one they have seen. I'm filing suite against my selling dealer, the ford dealer who I brought the vehicle to for service, ford motor company. I'm suing the selling dealer because they NEVER went through the " bs maintance schedule with me there for as a average consumer I would not no, The ford dealer I brought it to for service for not taking the vehicle apart to determain what the issue was " and to determain cause " and ford for denying a warranty claim. Oh and don't bother calling the ford customer service line. the rep told me that because the fuel filters and maintance was done at a non ford service place I should sue them individual shop not ford because it may not have been done right!!!!!! this is a guy who is sitting behind a computer know's nothing about my truck! they are trained now, this is a major issue with the new diesels, becareful this isn't "ford tuff" it's ford junk! I would be more than happy to assist anyone if they are having the same issues,
This is a forum generally geared towards people who are enthusiastic about their vehicles.
If you'd like to bash a vendor or product, there are other venues to do it. You could have written this up tactfully instead of blaming everybody else. There are a number of things that can cause fuel system failure, including, but not limited to, poor quality fuel, lack of maintenance, component failure. So what what is your local repair shop doing to complete the repair? When there is metal contamination in the fuel system, the entire fuel system needs to be replaced. There is a number of components that you CANNOT clean the metal fragmentation out of and they MUST be replaced. Fuel rails and injectors come to mind. I'm not trying to throw rocks, I'm just looking at it from the other side of the coin. I'm sorry to hear about this problem you're having, and I hope Ford comes through for you. Where are you located? PM me your VIN. |
Re: 2009 Ford F350 Fuel Pump Failure
OOPS did I do that...........
haha ![]() but dude that sucks sorry th hear about ur truck |
