Oil leaking from glow plugs
I have found the culprit of my oil leak. Traced it up to a glow plug on the passenger side. Anybody else had this problem?
Have seen a couple harnesses leak.
Please explain about the harness leaking. Mine is coming straight out of the side of the block.
Just wondering, how does a glow plug leak engine oil? I thought they were installed in the combustion chamber. You sure it's not leaking fuel/combustion residue?
Not sure. Definitely not a mechanic here just going off what I see. Guess it could be running down from the valve cover?
They mean that wiring harness that sticks out through the valve cover.
^^^ Yes.
The glow plug is about 2.5" past the valve cover. DO NOT try and take them out of a 6.4 unless you have the sleeve to do so, unless you wanna take the valve cover off to fish it out when you drop it. ![]() The harness just pulls out, but you need a special tool to do it. |
Good to know..
