Engine surging at idle???? - Ford Powerstroke Diesel Forum
Old 01-06-2010, 09:31 AM
OK, this is a question for a buddy of mine. He says if he leaves it idle for a little while it will start reving up or surging however you want to call it. His truck is an 08 all stock except for lift and tires.
Old 01-06-2010, 11:10 AM
Is it only when it's cold outside. Truck has a high idle to warm the engine.
Old 01-06-2010, 11:25 AM
It revs the engine up and down?
Old 01-11-2010, 04:51 PM
RPM probably not changing that much, probably the egr cycling?? Just a thought
Old 01-30-2010, 12:15 PM
read the owner's manual, it states the engine will do this & all is normal.
Old 01-31-2010, 03:08 PM
I actually had mine do the same thing last night. It was almost like it had a lope idle or something; it would rev up to about 550RPm then back to 500RPM and just keep doing it. I turned it off then turned it back on and it wen away.
Old 01-31-2010, 06:09 PM
<<< 6.4 Powersmoke
This is becoming really common it seems. I have seen numerous threads, and I too have been having lope idle and smoke problems. More so since I updated to the strategy flash system.
Old 02-01-2010, 04:57 AM
Powerstroke Techie
Rolling idle is set by something changing the torque request.
See it a lot more with tuned trucks than stock ones. Try turning the A/C or defrost off. It may be the clutch kicking on and off if the idle isn't changing a lot that may e what is going on.
