Coolant smell??? - Ford Powerstroke Diesel Forum
Old 12-28-2009, 06:01 PM
<<< 6.4 Powersmoke
Coolant smell???
I have recently started smelling coolant pretty strongly. Definitely more so than usual. The level of fluid doesn't seem to change, and I haven't added any in a LONG time. But I am smelling it fairly strong now.
There is pressure in the cooling system, but it doesn't seem excessive. I am lost... anyone
Old 12-29-2009, 02:37 AM
If you smell it, start looking. Check the radiator and hoses, sometimes the o-rings leak. Have you had any work done recently? (not just coolant related work)
Old 12-29-2009, 08:40 AM
<<< 6.4 Powersmoke
No work done recently. No engine work done ever actually.
Old 01-11-2010, 10:33 PM
Check o ring at radiator hose middle front bottom. I took mine in, $244.00 to fix, not under warranty. I have had white exhaust rarely, the shudder, the billowing exhaust and noted I lose about 1/2 gallon antifreeze each time. The antifreeze odor was present. Good luck...
Old 01-12-2010, 01:21 AM
Take the truck out and get it up to temp and flog her real good. Then immediately pull over and open the cap just enough to relieve the pressure built up.
Post up how many seconds it hisses for. Anything more than 1-2 seconds and you may have the same problems as me.
Old 01-12-2010, 01:34 AM
whats the chances that the egr is out?
Old 01-12-2010, 07:43 AM
<<< 6.4 Powersmoke
I like to check the pressure when I get home, and when I get out of the truck I usually smell coolant. When I loosen the cap, it takes a bit to relieve pressure, and there are also bubbles I can see coming up when the engine is running. But I don't think the bubbles are a problem. I have a coolant combustion gas tester, I will test it today to see if there is C02 present. I REALLY HOPE NOT I thought my cap was loose when I first started smelling it, but that isn't the problem.
Old 02-02-2010, 02:37 PM
hey
sounds like u may have head gaskets or thermostats failing or both just got done doing jesses his was head gaskets just join not to long ago
