need some halp
ok i have a 04 6.0 its blowing some white smoke under acceleration i would around the 2k rpm mark. i haven't not experienced any power loss at all the truck runs good with no hesitation. the white smoke only last about 5 to 10 mins when i am driving then it goes away also i only see it in the morning and i do not see when i come from work at all. i took it to the dealer they told me that egr cooler was fine. some other problem that i think it might be:
1. could i have a leaky injector that could be leaking some fuel causing the white somke? 2. could there be possible condensation forming because of the difference temperature in the morning and the evening? 3. possible egr and oil cooler? 4. head gasket? now i thought about this and i do not have lack of power. also i would assume that i would the see the white smoke any time i would start up? i really don't know what the possible could be. so anyother input would be great. |
I would think possible condensation if you only get it in the morning. Has it been wet in cleveland recently? If you post this in the 6.0 section, maybe someone else has had the same symptoms.
ahaha damn i thought i was in the 6.0 section could a mod move this to the appropriate section please. as far as the weather goes no its been pretty dry so far even if it did rain it would move in and out fast. thanks for help.
