Can't Find Engine Block Element Pins! - Ford Powerstroke Diesel Forum
Old 10-21-2009, 04:30 AM
Exclamation Can't Find Engine Block Element Pins!
2010 F-250 6.4L. No factory engine block heater option. Have read that this engine shipped with the heater element installed, just buy the cord and plug it in.
Was further told that the pin connector is located near the starter.
Bought cord. Crawled under truck with flashlight. Searched for 15 minutes.
Can't find pin connector.
Does anybody have a diagram or a photo they could post?
I'd be eternally grateful (and toasty warm).
Old 10-21-2009, 07:14 AM
I was wonderin the same thing. My truck didnt come with the cord but i was told everything else is there. So this is something im interested in knowing also
Old 10-21-2009, 07:16 AM
hahah... if you look at the thread on the "active topics" it just says "can't find engine block..." which is soooo true!
I can follow my cord and try to find the connector for you. Give me a little bit.
Peter
Old 10-21-2009, 08:05 AM
Smile
Thanks, Pete. I really appreciate it.
Old 10-21-2009, 08:52 AM
is the cord really short?? mine had a connector right below the rads, RH frame rail. Is this the connector you are searching?
Old 10-21-2009, 09:16 AM
IDK, how different the 6.4L is from the 6.0L, but there is a spot to plug in the block heater cord right above the starter. On the 6L it is pretty easy to see, must be different than the 6.4L. Good Luck on getting everything figured out!
-French
Old 10-21-2009, 09:43 AM
Exclamation
I don't think so. The cord I purchased has a 2-prong female receptacle with a screw-on collar to keep the cord fastened to the heater element's prongs.
I was expecting the male prongs to be sticking out of the engine block.
Old 10-21-2009, 10:43 AM
if I followed that harness up further it appeared to branch in two. Can you take a pic of your cord?
Old 10-21-2009, 10:54 AM
I'm at work and don't have access to it or a camera. But I bought it off e-bay.
Old 10-21-2009, 03:58 PM
I haven't seen mine but have been told the heater is above the starter. The above photo is the wire separator that pulls apart if you forget to unplug in the morning.
