Can bad EGR valve allow coolant into engine oil? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 09-27-2009, 08:23 AM Thread Starter
My dealer and tech say no but this doesnt seem right to me. There is a hose going from the EGR vavle to the coolant bottle so seems to me its possible. What are your thoughts?
2008 Dark Stone F250 CC,4x4 Lariat, Job3, 3.73 gear
Banks CAI
ATS Painted Flares
Eaton Front E-Locker
sawtooth1 is offline
post #2 of 22 Old 09-27-2009, 12:33 PM
greasltn's Avatar
There is coolant in the EGR system, but no oil, so I don't see how they could get cross contaminated.
greasltn is offline
post #3 of 22 Old 09-27-2009, 04:38 PM
Powerstroke Techie
It would be nearly impossible for the coolant to go from the passages within the egr valve, down the intake manifold, and around the rings to get into the crankcase with the oil.
Power Stroke Magic, Inc.
FordDieselTech is offline
post #4 of 22 Old 09-27-2009, 09:58 PM Thread Starter
Ok so lets say its not the valve and that the EGR coolers were pressure tested and came back ok. So where would be the next places to look for a small leak into the engine? My last oil analysis should higher potassium levels and the coolant bottle lost about 1.5 inch of coolant. So somehow it made it to the engine oil but not sure how. Thanks
Banks CAI
ATS Painted Flares
post #5 of 22 Old 09-27-2009, 10:08 PM
if the 6.4s have an oil cooler like the 6.0 then that would be my guess, someone else might know
mikeproc is offline
post #6 of 22 Old 10-01-2009, 07:24 AM
ZeroOne's Avatar
Ever run low on coolant? Blown radiator ever?
Credit to "BushPilot" on TDG.
ZeroOne is offline
post #7 of 22 Old 10-01-2009, 10:19 AM Thread Starter
No and hopefully not. I've run just a tad low on coolant but not sure if its going into the engine or if somehting else. My postassium was up a little on my last blackstone report so was a little worried. However, they pressure tested the system and found no problems.
Banks CAI
ATS Painted Flares
post #8 of 22 Old 02-14-2012, 02:34 PM
NVHunter83's Avatar
Sawtooth1, I'm curious about what you discovered with your issue and if you had it fixed.... I've got a 08 and my truck has the identical problem you described. My coolant bottle runs an 1-1.5" low on coolant and my Black Stone report says I have 0.08 coolant in the oil. My truck is totally stock, has had 2 radiators replaced and that's it...
Was your issue the EGR or cavitation of the front cover. My aluminum #s were high as well.... I know this is an old thread, I just need help. Thanks!
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #9 of 22 Old 02-14-2012, 02:42 PM Thread Starter
Well I still have the original EGR setup and still have a little coolant loss. The funny thing is I change oil every 5k and sometimes need coolant but sometimes I do not. The front cover had a oil leak and was replaced but still have issue. Now last month I changed to a new tuner that closes the egr valve so curious to see if it changes any of the lost coolant.
Banks CAI
ATS Painted Flares
post #10 of 22 Old 02-14-2012, 03:04 PM
The EGR and the timing cover can cause coolant to contaminate the oil.
This happened to me back in 2010 with only 20,000 miles on our truck.
Timing cover corroded and leached coolant into the oil, the dealer refused to acknowlege the oil analysis we had taken, told us the oil was not changed enough due to the jelly like sludge in the engine, yet the oil analysis report said the oil met OEM requierment even with 424PPM of sodium in the oil, Flagged for excessive coolant and we had to repair the engine ourselves.
Locked up turbo and sludged out 6.4 engine
The use of conventional coolant just wont do in these trucks.
Feel sorry for you guys that think is supposed to fix this mess, they wont and cant do it
Javier
ranchopower is offline
