My 08 6.4 won't start after a fresh install of a new HPFP, pump was definitely bad as it was seized, threw the p2291 and p0087 codes as well, anyways did the pump swap but I'm still getting no start, do I need to bleed the hp side?
Batteries are fully charged, fuel injector pump is new, also a has new HFCM and new filters, everything was reinstalled and torqued properly(double and triple checked), when I try to crank the engine it sounds like just the starter is turning it, unless I shoot it with wd40 in which case I get some compression and smoke out the tail pipe.
Truck has DPF/EGR deletes, H&S XRT pro tuner.
Need some assistance soon as I'm in welding school and having to share a vehicle with my mother, ain't easy.
