2008 Ford F-250 radiator issues - Ford Powerstroke Diesel Forum
Old 07-17-2009, 08:08 AM
Good day fellow Forders,
I have 2008 F-250 that is burning through radiators faster than tires. I will add that I use MT's as well. This is the third radiator and it is being installed as I am writing this. My truck has 76,000 miles. I am attempting to prevent further red-***. I know I am not the only one.
Is there an aftermarket that works and if there is, what is it and is there a high performance Intercooler that will work with it. Cough it up guys before I start spending the kids college money. Thanks, Ken
Old 07-17-2009, 08:17 AM
Did they warranty any of them?
Old 07-17-2009, 09:18 AM
Yes, My problem is that one day they won't. I think this new one will do the same thing.
Old 07-17-2009, 09:28 AM
I have had the same concern. Mine was changed once around 45,000. How long will they warranty them?
Might be worth talking to these guys...
928-681-6717
mcculloch@alumrad.com.
I have had a lot of radiators fixed. That's still an option.
Old 07-17-2009, 10:11 AM
According to the mechanic it is only supposed to be 12/12000. We all know how long it takes to get 12000 miles. I had to raise a little hell this time. Also I have been doing business with the same dealership for a couple of years and that may have made the difference.
Old 07-17-2009, 11:08 AM
<<< 6.4 Powersmoke
Does your truck have the Venturi T installed? Here is a link to what your bottle should look like.
Does this have the Venturi T?
Old 07-17-2009, 05:43 PM
Send a message via Yahoo to Puttser
i have had 8 installed in my truck- finly had to replace head gaskets. cured
Old 10-04-2009, 12:10 PM
They are having problems with the thermostats sticking with pressure spikes. Make sure that your dealership installs new t-stats this time. And just so you all know the T-stat are covered tell 5 yr-100,000 miles, also covers "caused" damage.....radiator.
Old 10-06-2009, 02:49 AM
Mine has finally started leaking
I have a Job 1 truck with 48k miles on it. The radiator has just started to leak a little. Worst case I have seen is about a 3" diameter puddle after about a 50 mile trip. Dealer says that it is not covered by warranty. My questions are:
-How quick do I need to get this taken care of?
Is this going to get progressively worse?
Thanks for your help.
Old 10-06-2009, 04:23 AM
Check with another dealer.
By following this forum, many have gotten the replacement done under warranty up to 100k. Check your diesel supplement manual, it should state all engine-related parts covered up to 100k/5yrs. for the 6.4L, including the rad.
Maybe someone with radiator/warranty experience can chime in...
