Engine Cooling - $10 Radiator Bug Screen - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2009, 11:14 AM Thread Starter
H2C
H2C's Avatar
I am new to this forum, and diesel trucks (finally got my first one!), and have appreciated the tips and tricks I have picked up so far. I wanted to give something back, so here goes.
I live in the hot southeast of Texas and believe a "clean radiator is the best performing radiator". Consequnelty I keep radiator bug screens on all of my vehicles. I needed one for our new Powertstroke but didn't find any locally or for a price I would pay. Hence I built one for under $10 dollars and have attached the details. This way I have a custom-fit fine-mesh screen protecting my ride which gives full coverage of all radiator elements, AND I can quickly and cheaply make a new one when needed. (The mesh is substanially smaller than the radiator passages. This may require more frequent inspection or rinsing but it keeps the radiator clean.)
The parts are available from any of the major building centers. I used aluminum screen in a charcoal color so as to not be visible and to handle the engine heat (cost is $6.49 for a roll of 36" x 84"). Six brass grommets were used for mounting holes through which black plastic wraps were used to secure.
Minimal time (less than 30 minutes) is needed to make and install the screen. The attached photos give the build details and some pictures of the result.
I know this is a minor item for a vehicle and not in the league of engine tuning, but I hope it helps keep your ride cool and in peak performance.
Name:	Screen - Final Form.JPG
ID:	9456   Click image for larger version
Name:	Screen - Build Detail.JPG
ID:	9457   Click image for larger version
Name:	Full Screen.JPG
ID:	9458   Click image for larger version
Name:	Installed Screen.JPG
2009 F-250 6.4L, 275/65-R20's, Crew Cab, Short Bed, Tri-Fold Tonneau, Centramatics, AirLift Load Lifters and WirelessAIR, BushPilot's Block Heater and 12VDC Charging Mods, ATTA Undercover Fuel Tank & Toolbox, EDGE Evolution CS.
H2C is offline
post #2 of 4 Old 06-21-2009, 11:19 AM
Thats pretty neat! Good Idea
03-blue-Powerstroke is offline
post #3 of 4 Old 06-21-2009, 11:25 AM
back in the saddle
shu873's Avatar
That's an excellent first post! Welcome to the org!!!
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #4 of 4 Old 06-21-2009, 11:31 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
Awsome post, Welcome to the addiction
