Anyone Runnin Rize 4 Link kit? - Ford Powerstroke Diesel Forum
Old 06-09-2009, 01:26 AM
I've got one on the way and wanted to know what the install was like. Also, hows the ride?
Old 06-09-2009, 10:30 AM
mine is in the garage, just havent had time to get it on the truck!
let us know how you make out
Old 06-09-2009, 05:31 PM
mines getting put on in 3 days. Had to buy a 46mm socket so i can get the pitamn arm off.Going to put a 2 inch spacer under springs to get 10 inches to clear my 40inch tires.also had to buy the icon adjustable panrod Bar to compensate for the extra 2 inch of lift
Old 06-10-2009, 05:23 AM
I've had one on for the last 20,000mi. Rize 8" 4-link, with OUO traction blocks in the rear / stock springs.
Love it! It's hard for me to compare, since this is my first full size truck, but the shop that did the work were pretty wide-eyed at how nice it rides. They said its as smooth as a half-ton truck. The feel of it contradicts the look, in a way. People expect a big truck to have a harsh ride.
As for the install, I had a shop do it. Seemed pretty straight forward, with no problems. One tip... make SURE your drop-pitman / nut (if your kit has one) is TIGHT before you put the track bar drop in place. No wrench will fit once that bracket is in. Not one that will allow the 350ft-lbs of torque needed on the pitman nut anyway.
Old 06-10-2009, 05:53 AM
Truck rides better than stock and my truck is at 16" on 40's. Install pretty stright forward depends if you get an old kit or the new style with the poly bushings (I heard that ones a lot easier to install) Its not a drive way install by any means. You'll really like the kit and the ride if you plan on doing any High HP mods I would suggest OUO traction blocks or modifying Rizes rear traction brakcets with gussets and plates.
Old 07-04-2009, 03:45 PM
I finally finsihed the rize install.It is pretty basic and easy to do.The only problem I have is the frt diff angle is to far down after the alignment was done so the frt driveshaft binds when 4 wheeling.You want to run lots of caster at leat 3.5 degrees on these trucks so when you do this it pulls you pinion angle down which makes a bad angle in the frt.I also had to put a 1 piece drive shaft in the rear.Once it was installed it eliminated all vibrations.if I had to do this all over again i would do 8 inch lift with 38s on 20 inch wheels.It seems like 10 inch lift maxes steeing/suspension to much to be real reliable when 4 wheeling hard
Old 07-04-2009, 04:36 PM
10" is the safe max for the steering for sure.
And yes when the Rize droops it does cause caster to go more positive due to the length of the lower link. You may be able to clearance the yoke to keep the front driveline from binding.
Or, index the t-case to give the front shaft a lesser angle.
Old 07-04-2009, 06:09 PM
How much work is it to index the transfer case?I might try that
Old 07-04-2009, 06:47 PM
OUO makes a transfercase index ring I believe and Im sure Dan can get you a price... if you installed your lift, you can install the ring... they arent too difficult...
Old 07-04-2009, 06:56 PM
Need to unbolt the t-case from the trans to put the indexing ring in.
You'll also need a new transmission crossmember to clear the front driveline as the front output of the t-case is now lower and the factory crossmember will not clear the shaft.
If you can see where it's binding you can clearance it some with a die grinder to keep it from contacting though.
Actually Attitude Performance makes the ring that we sell.
