Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #11 (permalink)
Old 07-04-2009, 08:00 PM
DunesRunner08 DunesRunner08 is offline
well send me a PM for a price because I am going to need one on the new truck dan.... its a 2000 F350 CCLB
  #12 (permalink)
Old 07-04-2009, 08:02 PM
motocaptain845 motocaptain845 is offline
Did mine myself ! Not hard @ all, I also did Icon coilovers with the icon hoop. By far the hardest part was cutting old stock coil bucket off. I love the ride but if i did it over i would use the icon 4 link.
  #13 (permalink)
Old 07-04-2009, 08:22 PM
toylet toylet is online now
Its not contacting.The angle is just really bad and you can feel it when driving in 4 hi at about 15mph.I dont thik that a different drive shaft is going to fix it.If I lower the out put of the transfer case do i have to worry bout oil starvation in the transfer case?
  #14 (permalink)
Old 07-04-2009, 08:28 PM
The only other problem that I ran into when installing my 10 inch lift is the rear shocks
have to be really long to work(like 16 inch travel).So what im planning on doing next week is cutting factory rivets off the rear shock top mounts .and flipping them down so
the top mount will be alot closer to the bottom shock mount.I will just have to buy 8 bolts for this mod.I hope it works.Cause I cant afford those expensive 16 inch travel shocks.would like to keep my bilisten shocks
  #15 (permalink)
Old 07-05-2009, 05:38 AM
Jesse@MBRP Jesse@MBRP is offline
My kit will be here Tomorrow so I'll let you guys know. Any special tools I should have on hand??
  #16 (permalink)
Old 07-05-2009, 08:30 AM
46 mm socket and a "large" pitman arm puller.The regular size pitman arm puller will not work
  #17 (permalink)
Old 07-06-2009, 05:15 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Indexing Ring:
Attitude Performance Indexing Ring - Driveline Accessories - Truck Toyz Store
Crossmember:
Custom Transmission Crossmember - Driveline Accessories - Truck Toyz Store
We haven't had any oiling issues to date and we've installed quite a few.
I know Matt from Attitude has been using them for years without issue.
  #18 (permalink)
Old 07-06-2009, 06:07 PM
ExtremeFord4x4 ExtremeFord4x4 is offline
Also you will need a 1 7/8" wrench for the jam nuts on the heim joints(if your kit has them). Install isn't bad at all, it is the only lift I have seen with full color pictures in the instructions. Which is a big plus. PM me if you need any help.
