Tires Rubbing - Ford Powerstroke Diesel Forum
Old 06-04-2009, 04:24 PM
Tires Rubbing
I got a 6" pro comp lift and 37x13.50 toyo mt's. They rub at full turn and if I'm turning and hit a bump or anything uneven really. Anyone else having this issue with 37s and 6" lift?
Old 06-04-2009, 04:27 PM
what year truck?
Old 06-04-2009, 04:33 PM
Sorry, its a 2008
Old 06-04-2009, 04:42 PM
Where are they rubbing?
Old 06-04-2009, 04:45 PM
I have the same issues with a 4 inch lift and 37s on stock rims. The tire on the drivers side rubs on the side of the radius arm. I was told that maybe a adjustable track bar would help to center the axle because the drop bracket was not enough.
Old 06-04-2009, 04:56 PM
They are rubbing on the bottom of the plastic in the fenderwell. I trimmed it up some and it helped but it just drives me insane. It's not that bad but I don't like it. Was thinking of putting a 7" spring in the front but wasn't sure if it would work with the lift components of the 6". Its a pro comp. And 37s on a stock rim will rub the radius arms because of the backspacing on the rims.
Old 06-04-2009, 04:59 PM
I also have a slight vibration when taking off but its only for a second. I have the carrier bearing drop kit but it still vibrates a little. Was thinking about getting some traction bars? Any info, prices, brands?
Old 06-04-2009, 05:02 PM
I had the same problem with the inner fenders, I took a peice of 1/4" threaded rod, a washer and a acorn nut(attached to the inner fender) and the other side attached to step bar bracket and pulled the inner fender away from the tire. It is invisable unless you crawl under the rig and look up.
Old 06-04-2009, 05:31 PM
If you could take a pic and send it to me, it would be greatly appreciated.
Old 06-04-2009, 05:55 PM
It is raining heavily right now, I will take a picture tomorrow and send it to you.
