Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #31 (permalink)
Old 05-12-2009, 08:46 PM
mohlson mohlson is offline
A few more pics for ya, The last one is my old truck next to a stock one
  #32 (permalink)
Old 05-13-2009, 04:28 PM
perfection perfection is offline
Buckeye Power Strokes
Send a message via AIM to perfection
thanks i just ordered my tires today i got the toyo mts so that means i gotta order my level kit asap
  #33 (permalink)
Old 05-13-2009, 07:04 PM
pierre3737 pierre3737 is offline
What size tires did you get? What levelling kit are you getting? Just curious as like I previously mentionned I'm worried about the trailering height.
  #34 (permalink)
Old 05-13-2009, 08:05 PM
i got toyo mts 35x12.5 20 im not sure which leveling kit to get yet i dont wanna spend a ton a money on it and then i will prolly order some airbags for the rear im not sure which to get etiher so please help me out here
  #35 (permalink)
Old 05-13-2009, 08:10 PM
I get all of mine on ebay
05-08 FORD F250/F350 2.5" LEVELING LIFT KIT + 1" BLOCKS:eBay Motors (item 260405979157 end time May-16-09 08:41:01 PDT)
this should do the jobhttp://cgi.ebay.com/ebaymotors/05-08-Ford-2-5-Leveling-kit-with-shocks_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q 3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c29 3Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZi tem2ea54695aeQQitemZ200341362094QQptZMotorsQ5fCarQ 5fTruckQ5fPartsQ5fAccessories
Or this one. I have used both, easy install
  #36 (permalink)
Old 05-13-2009, 08:17 PM
2.5 Lift Kit FORD F250 F350 05-08 07 06 4x4 sd leveling:eBay Motors (item 310140892885 end time May-14-09 21:26:19 PDT)
this one works too.
  #37 (permalink)
Old 05-13-2009, 09:24 PM
DCSpecial DCSpecial is offline
Supporting Vendor
BDS 2 Inch Front Spacer Kit - 2008 Superduty 4wd - 2008-2009 F250/F350 SRW 4wd - Truck Toyz Store
Click the Configure button if you want to upgrade to Bilstein or Icon shocks for a better ride.
  #38 (permalink)
Old 05-13-2009, 09:53 PM
yeah, trucktoys has all you should need to get the job done and why not support fellow .orgs?
  #39 (permalink)
Old 05-13-2009, 10:06 PM
i already have ranchos on there stock do i need to get other shocks
  #40 (permalink)
Old 05-14-2009, 07:21 PM
Supporting Vendor
I would get longer shocks to make up for the additional 2" of height.....and also since the factory shocks, even the "Ranchos" pale in comparison to the performance of a Bilstein or Icon shock.
