Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #21 (permalink)
Old 05-12-2009, 08:13 PM
perfection perfection is offline
Buckeye Power Strokes
Send a message via AIM to perfection
Originally Posted by pierre3737 View Post
I've wanted one also for my F-350 but it's all fine as long as you don't put a load in the back or haul a heavy trailer. Then it looks like your F-350 is a ranger with a ton of bricks.
There is also the issue of having one wheel sticking out of the fender and the other sticking in about an inch making look like your dogtracking unless you add all the parts that they tell you after you have purchased the levelling kit. But they look good unloaded and check the trucktoys website they have tons of pics.
so if i haul a trailer it will look like ****....
  #22 (permalink)
Old 05-12-2009, 08:17 PM
mohlson mohlson is offline
I have seen it on factory wheels but I recomend 35's. my 37s rubbed with a 4 inch so I went another 2 to make em clear. the rubbing wasnt bad though just needed to pull the inner fenders back and slightly shim my bumper out. If I had a narower offset wheel they would hav worked fine though.
  #23 (permalink)
Old 05-12-2009, 08:20 PM
Mine looked fine with a trailer
  #24 (permalink)
Old 05-12-2009, 08:26 PM
i haul a skid steer trailer what brand level kit you have and how much
  #25 (permalink)
Old 05-12-2009, 08:33 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Load assist air bags are the answer for the rear.
My 07 sits level and I can tow 12,500lbs no problem and keep the truck level.
Also can put a 2200lb pallet in the bed and hang 700lbs off of the hitch at the same time and keep it level.
  #26 (permalink)
Old 05-12-2009, 08:35 PM
Heres a few more pics. it only takes at most an hour to put on.
  #27 (permalink)
Old 05-12-2009, 08:36 PM
how much r those and the level kit
  #28 (permalink)
Old 05-12-2009, 08:37 PM
yup! airbags are great
  #29 (permalink)
Old 05-12-2009, 08:42 PM
if i have an 08 f350 diesel fx4 do i need 2 inch or 2.5 inch level kit
  #30 (permalink)
Old 05-12-2009, 08:44 PM
a 2.5 with airbags would work great
