Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
  #11 (permalink)
Old 05-11-2009, 08:48 AM
DFW64 DFW64 is offline
Originally Posted by 2008fx4 View Post
i'll bite - pro comp:
Is there a replacement block on there or is it the factory block?
  #12 (permalink)
Old 05-11-2009, 11:18 AM
2008fx4 2008fx4 is offline
Originally Posted by InMotionJosh View Post
My Favorite Leveled Truck on Here..
thanks!!!
it came with an aluminum add-on block for the rear, but i ended up just using a stock f350 block on my 250, and added ride rite helper bags.
  #13 (permalink)
Old 05-12-2009, 06:44 PM
DSL_PWR DSL_PWR is offline
That is the next thing that I am going to do to mine as soon as I get my new wheels/tires.
  #14 (permalink)
Old 05-12-2009, 07:22 PM
mohlson mohlson is offline
Heres My 05, 2 inch leveling kit in front and factory f350 blocks in rear. 20x10 monsters with -12 offset and 35s. slight triming to make em not rub
  #15 (permalink)
Old 05-12-2009, 07:55 PM
perfection perfection is offline
Buckeye Power Strokes
Send a message via AIM to perfection
do your leveling kits make that big of a height differnce
  #16 (permalink)
Old 05-12-2009, 08:05 PM
I loved that truck but its gone now, dropped it off at Woodhouse ford for a new injector and on a test drive hit a tree......now I have an 08
  #17 (permalink)
DCSpecial DCSpecial is offline
Supporting Vendor
FWIW, since you use the truck for snow plowing I would definitely recommend a spacer kit and keep the stock springs.
Something like the BDS kit with Icon shocks (click the Configure button). Would be the best setup as the Icons are clearcoated and perform extremely well.
BDS 2 Inch Front Spacer Kit - 2008 Superduty 4wd - 2008-2009 F250/F350 SRW 4wd - Truck Toyz Store
A dual stabilizer is also a nice upgrade along with an adjustable trac bar, but not "necessary" to complete the install.
  #18 (permalink)
Old 05-12-2009, 08:09 PM
your factory 20's are 34 inches tall, so 35s fit no problem. A 20x9 +18 offset works the best but I like the wider offset
  #19 (permalink)
Old 05-12-2009, 08:11 PM
pierre3737 pierre3737 is offline
I've wanted one also for my F-350 but it's all fine as long as you don't put a load in the back or haul a heavy trailer. Then it looks like your F-350 is a ranger with a ton of bricks.
There is also the issue of having one wheel sticking out of the fender and the other sticking in about an inch making look like your dogtracking unless you add all the parts that they tell you after you have purchased the levelling kit. But they look good unloaded and check the trucktoys website they have tons of pics.
  #20 (permalink)
could i go 37s with the level kit or will they not fit
