| 6.4 Exterior Discussion Body and Accessories Talk |
upgrade sway bars?
Does anybody know or have an upgraded sway bar system for our trucks?
I feel like Im getting a little much body roll and wanted to see if I could eliminate a little bit of it. Thanks |
Front one is fine but that silly rear one is just stupid, get a earlyer one and miss parts from a junk yard. It will bolt right up to the axle..might need a little fab to attach to the frame. It worked fine on mine but since its a '97 with '08 axles I had the frame holes already. Corners like a slot car!
I'm pretty sure Hellwig makes a rear one. Be prepared...I just got the factory one put on the rear and had to drop the fuel tank to tighten the bolt on the drivers side frame rail. My tank is aftermarket but I was told it would be the same for the factory tank (maybe, maybe not).
I got mine off with out having to drop the gas tank
Well I guess its just an aftermarket thing.
I could not get to mine without lowering the tank...was a biotch
I hear that...I got charged an arm and a leg.
