| 6.4 Exterior Discussion Body and Accessories Talk |
Biggest Tire on Aftermarket 20x9 with 2.5" Leveling Kit
I need a little help hear. I am planning on getting the KMC Monsters 20x9 wheels. I have a 2.5" Tuff Country level kit. Can anyone give any input on this. I am thinking about a Nitto Terra Grappler 295/60/20, which is 34.45" tall and 12.36" wide. I am currently running a Toyo Open Country MT 285/75/18 on stock wheels, but that tire is only 11.6" at 35.1" tall. The Nitto may be a little to big and might rub with those wheels
or maybe I can go a little bigger.... Thanks for the help in advance
I'm running 35X12.5X20 Toyo MT's on my 20"x9" Incubus Recoil Wheels.
I clear them fine. At FULL lock, Left or Right, I will get a tiny bit of rubbing on the Inside Fender Lining. It is Plastic, so I just back off the Tight Turn a little. I would say it Does NOT Effect my Turning Radius though. |
I am running 35x12.5x20 Nitto Mud Grapplers on a 20x9 XD hoss wheel. Little rub at full lock but that is, and it is without a leveling kit.
Thanks for the input guys, I am pretty sure now that the Nitto Terra Grappler 295/60/20 will fit no doubt if you guys are running a 35" with 20x9's and getting little rub.
35x12.5 on a 20x9 here. No rubbing!
i'm doing 36/15.50/20 on my 20x9's but i have a 6" lift.
did you get the +16 offset on the monsters?? with a 35" tire you may have to do some minor trimming of the plastic at the rear of the fender well.
The tire is a Nitto Terra Grappler 295/60/20. It is a 34.45" tall and 12.36" wide tire, which I think will be fine with that offset and 5.74 backspacing
