opinion on this Leveling kit?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-02-2009, 11:26 AM Thread Starter
KRAYZKAJUN's Avatar
eBay Motors: 05-08 FORD F250/F350 2.5" LEVELING LIFT KIT + 1" BLOCKS (item 250379746110 end time Mar-07-09 07:02:20 PST)
anybody??
2011 Dodge 3500 c/c Dually 4x4
Cummins HO
KRAYZKAJUN is offline
post #2 of 12 Old 03-02-2009, 12:07 PM
InMotionJosh's Avatar
It will require you to stack your back blocks with the ones they provide which is never a good idea. Also when adding the spring spacers up front you either need a shock extension or new shocks.
It is cheap, but remember, you get what you pay for.
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #3 of 12 Old 03-02-2009, 12:33 PM
The quality of the components seems ok, but it doesn't appear to be a complete kit.
po-po 5.0 is offline
post #4 of 12 Old 03-02-2009, 01:32 PM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 5 Post(s)
Very true
I was going to say the same thing, but what goes on the coil to raise the front?
-Julian
4th 6.fo
TwinTurboStroker is offline
post #5 of 12 Old 03-02-2009, 02:58 PM Thread Starter
KRAYZKAJUN's Avatar
thanks fellas
Cummins HO
post #6 of 12 Old 03-02-2009, 03:21 PM
I was looking almost the same kit but the complete 2.5. The front has the aluminum blocks that go under the springs and the rear blocks that stack. I saw that yall said that the rear blocks were not a good idea to do it that way, but what about the coil spacers underneath the coils?
jpfitz55 is offline
post #7 of 12 Old 03-02-2009, 03:25 PM
Coil spacers arent the best way either but its probably safer than stacking the blocks.
post #8 of 12 Old 03-03-2009, 09:27 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Get a quality kit thats complete. I'd never recommend Aluminum blocks or spacers!!!
CT Performance, Inc. is offline
post #9 of 12 Old 03-03-2009, 09:40 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I would pass on it!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #10 of 12 Old 03-03-2009, 12:57 PM
jpfitz55 is offline
