| 6.4 Exterior Discussion Body and Accessories Talk |
37" and 22's or 35'' and 20's
I have an 2008 Ford F350, and im installing a 6'' lift. I need help with witch wheel and tire setup to go with 37'' tires with 22's or 20's? Also if i go with 37" tires over 35" with i notice a big diffrence in mpg? If you know where i can get a good deal let me know. Thanks
i can get you a good deal on wheels, tires, and lift kit if you havnt decided on which one too go with yet.... -Raul |
For a 6" definitely 37" tires. As far as rim it's a personal preference...I personally like 20" wheels on tires 38" or less. If you plan on doing any real offroading the more sidewall the better as well.
37's with a 6 inch lift is the way to go. I have 22's and enough side wall to air down if needed without risking damage.
What are you getting for MPG with your 37" tires. Thanks
I'm getting 11.5mpg in the city and up to 14mpg on the hwy, i have no tuner or engine mods.
35's are way too small for a 6" lift on an 08
I made my calculations by using a GPS to calculate total mileage for an etire tank, since my odometer / speedometer / lie o meter are all off now. Just curious because I've heard lots of folks with DPF and tuners getting much better mileage than I am, but you are the first who is running a stock vehicle and claiming better mileage with even larger tires. What gears do you have installed?? Thanks |
