Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 12-27-2008, 08:04 AM
Rick James Rick James is offline
Snow Plow Springs for Winch Bumper?
How much front end sag could I expect from adding 350-400 pounds from a winch/winch bumper? I already have a leveling kit, but I'm wondering if I'll have to level it again with the additional weight. I've searched and found that Ford does offer "snow plow springs", but I don't know what I have on the pickup now (no snowplow package) or if those springs would even be an option. Thanks for the help!
Old 12-27-2008, 08:56 AM
caryt caryt is offline
They might not call them snow plow springs but they have 4 different rates..5600, 6000, 6500 and 7k lbs ones. My dealer lists the 7k ones as snow plow. 3-400 lbs might drop the front 3/4"
Cary
Old 12-27-2008, 12:31 PM
Thanks caryt,
On a directfordparts.com it lists 7 different spring rates. I guess I'm just wondering what I have on the pickup currently. Would anyone know where to look?
Old 12-28-2008, 09:19 AM
Door tag will list it and you may still have a sticker on the coils.
Cary
Old 12-28-2008, 10:13 AM
DCSpecial DCSpecial is offline
Supporting Vendor
Yep, look at Front GAWR on the door tag.
My 6.0 with the snow plow package came with 6000lb coils.
I upgraded to 7000lb coils (F-450/550 springs).
Old 12-28-2008, 02:31 PM
Thanks, I have 5600# springs according to the door. Maybe it should have been obvious.
When you switched coils, did it lift the front or just firm up the ride?
Old 12-28-2008, 03:52 PM
Supporting Vendor
When I went from 6000lb coils to 7000lb coils I picked up 3/4" of lift.
Old 12-29-2008, 09:27 AM
You might also get new castor plugs if you go with the 7k springs, recheck your axle centering..you may also need a adj track bar.
Cary
Old 12-29-2008, 09:46 AM
Supporting Vendor
I did both the Icon cams and trac bar.
I used the cams from Icon's 2.5" leveling system.
Put me "out of spec" on the positive side of caster but it handles much better than stock.
