Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 12-23-2008, 06:11 PM
Goolsbymd Goolsbymd is offline
Project Abused
Removing Side vents
Anyone got any tips on compeltely removing them? Or is the dremmel coming out for this one
Old 12-23-2008, 06:13 PM
ford99PSD ford99PSD is offline
if im not mistaken there will be holes where the vents once were. are you completely removing them or just modifing them a little. if you are getting rid of them i might know someone that would want them
Old 12-23-2008, 06:38 PM
Project Abused
There gonna be complete gone, got a little somethin somethin goin in there, one piece billet painted/engraved
Old 12-23-2008, 06:42 PM
you feel like gettin them out of your hands? its an o8 right? this is also a free bump for you.
Old 12-23-2008, 06:56 PM
Project Abused
Ill prob hold on to them, yea its an 08.
Old 12-23-2008, 07:17 PM
JMart JMart is offline
Powerstroken Locksmith
I pulled the inner fender liner to get mine out. Once it was pulled I used the side of a deadblow hammer to tap the pegs out of the holes from the inside. I have taken mine out twice takes about 10 min each side.
Old 12-23-2008, 08:18 PM
jrod80 jrod80 is offline
I just pryed them out softly with a screwdriver with a soft rag behind it. Once I had the top I just worked my way around. I've had mine off three times.
Old 12-25-2008, 12:52 AM
ididntdoit5150 ididntdoit5150 is offline
Send a message via AIM to ididntdoit5150 Send a message via Yahoo to ididntdoit5150
ditto
Old 12-25-2008, 08:32 AM
kentuckybuiltf350 kentuckybuiltf350 is offline
you can access them from inside the engine compartment. pop the hood and then stand on something like a step ladder to get better access. just reach inside the fender and you can feel it. it has rectangular nubs with metal clips that hold the vent on. gently push outward on the vent and it will just pop out. be sure tou use your other hand to catch it so it doesnt hit the ground and get scratched.
Old 12-25-2008, 08:55 AM
matt05 matt05 is offline
Yah the easiest way I found was to go through the engine compartment, but I also taped around the badges real good and pryed behind them a little with a screwdriver. Sometimes you can't completely get your hand in to release one of the tabs, so the screwdriver helps.
