big rig ice recon running board lights - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-06-2014, 11:05 PM Thread Starter
dei2303's Avatar
Ok so i installed my running board lights yesterday and wanted to explain the process. I didn't take a lot of pictures of the mounting process but, I did take some of wiring and the lights on.
So the mounting process is really easy, as you just measure out the 62 inches or 48 inches respectively, then install hangers at those 2 points. Following that you space the remaining hangers as evenly as possible. If you have the stock running boards from Ford other than the king ranch you will have to make some clearance in the center plastic running board mount cover on both sides. I used the biggest drill bit i had and drilled the gap to get some clearance. Its that easy...
Next step is wiring. First i pulled the white wires (courtesy wires) and ground wires out of the plastic insulators. Set the white wires aside for now and ground the black wires to one of the mounts. Then ziptie them in a bundle and hide the bundle behind the front plastic running board mount. Next take the wires that you connect to the headlights and run them behind the lower section of your fender well insert. For the passenger side the red wire on the ice lights will connect to the yellow traced wire on the upper amber light, and the yellow wire from the ice lights will connect to the purple traced wire on the same light. On the drivers side the only difference in the wiring is instead of connecting the reed wire to the yellow traced wire, youll connect it to a blue traced wire coming from the upper amber headlight.
Ok now its time for the white wires. Pull the door sills as well as the kick panels in front of them. Pull the carppet back enough to find the little rubber grommets on the floor boards that Ford has put in for us to run wires through (a feature i love ). Pull the grommets out, and pierce them just enough for the wire to go through( I used a kitchen knife). Put the wire through it (one on each side). Just pull the wire completely through them. Next run the drivers side wire under the carpet to the passenger side ( i pulled the carpet back on the drivers side ran the wire to the passenger side then pulled the carpet back on the passenger side). Now connect the drivers side wire to the passengers side wire. On the passengers side of the truck next to the fuse box is a huge plug, disconnect it by pressing the tab and pulling the handle back to release the 2 ends. On the male side you will find a Yellow wire with grey tracer. Splice your white courtesy light wire into that wire on the male plug.
Now check that all the lighting works and button everything up. Your done grab a few beers with your friends and enjoy a long well done job.
ID:	269073   Click image for larger version
ID:	269081   Click image for larger version
ID:	269089   Click image for larger version
ID:	269097   Click image for larger version
08 f250 powerstroke lariat
ccsb 4wd automatic
leveled front w/ 35 x 12.5 surrounding
stock 20 in wheels
Recon smoked cab lights
Recon smoked third brake light
Recon smoked led mirror lights
Recon big rig ice running board lights
Mods to be done...
Theretrosorce hid conversion
Dpf/doc/ egr delete
Spartan tuner
6" black stacks aussie tips
S&b CAI
ARP head studs
dei2303 is offline
post #2 of 2 Old 04-06-2014, 11:11 PM Thread Starter
dei2303's Avatar
Some finished pictures.
ID:	269137   Click image for larger version
ID:	269145   Click image for larger version
ccsb 4wd automatic
stock 20 in wheels
Mods to be done...
Dpf/doc/ egr delete
Spartan tuner
S&b CAI
ARP head studs
dei2303 is offline
