Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4 Exterior Discussion
Old 12-02-2008, 04:20 PM
ncorey ncorey is offline
Whats Better Coil or Coilover?
Whats better like a rize lift with just the regular coil springs and good shocks, like fox, king, bilstien. Or upgrade to a coil over lift? I do mainly street driving with towing on the weekends, and light off road, like going wheeling in a field or maybe the sand every once and a while. Also for just doing that is it worth the extra money for the coilovers?
Old 12-02-2008, 06:47 PM
DCSpecial DCSpecial is offline
Supporting Vendor
Coilovers give you more adjustability and the springs used on coilovers can handle the abuse of severe use better.
Depending on the size of lift, the downside of coilovers is that you may get less wheel travel with a coilover than you would with a coil spring and shock due to the physical dimensions of the coilover itself.
Hope this helps.
Old 12-03-2008, 09:51 AM
caryt caryt is offline
Just a FYI Rize doesn't make a kit for a 00, you looking at a newer PS?
Cary
Old 12-03-2008, 01:24 PM
Yes I am going to buy a new PS with in the next couple of months
Old 12-03-2008, 01:25 PM
po-po 5.0 po-po 5.0 is offline
for street driving there really isn't any benefit to a coilover. They look cooler, but you're not going to gain anything.
