Best bang for your $ leveling kit. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-10-2014, 03:29 PM Thread Starter
xxxjagsfanxxx's Avatar
Send a message via AIM to xxxjagsfanxxx
I'm sure this has been discussed before. Just looking to do either a leveling kit or a 4" lift on my 08 f350. Looking for a decent quality, as I will be using it to haul a 16' stock trailer and occasionally a 25' gooseneck. But not looking to break the bank. I'm leaning towards just a leveling kit. But was curious as to what some of y'all are towing with and maybe some pictures. Thanks!
Sent from AutoGuide.com App
[COLOR="Red"][SIZE="2"]2002 F-350 ext. cab long bed 4x4
4 inch turbo back exaust with 6 inch miter cut stacks
isspro guages(boost and pyro)
S&B intake
boost fooler
TW 6 position chip
bd diesel turbo timer
8 inch lift
38x14.5x17 goodyear wrangler MT/R's
xxxjagsfanxxx is offline
post #2 of 10 Old 03-10-2014, 07:08 PM
Quoted: 2 Post(s)
i went through a similar situation.... couldn't decide between 2.5" or 3.5"... glad i went with the 3.5" looks sweet with the 37's. however, i dont tow that much. if you're towing heavy, i would stick with 35's maybe. my pic is in my sig, but i went and had a whole thread to help me decide. there are a bunch of pics in it.
35's and 2.5" Leveling Kit or 37's and 3.5" Levleing Kit HELP ME DECIDE!! PLEASE
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 10 Old 03-10-2014, 09:09 PM Thread Starter
So you did the 3.5 ready lift kit? How does she handle with a trailer? And Ill probably stick with a 35" tire if I do that. But who knows. Lol.
S&B intake
boost fooler
TW 6 position chip
8 inch lift
post #4 of 10 Old 03-11-2014, 07:02 AM
Quoted: 2 Post(s)
yep.. readylift kit. good quality stuff. only complaint was that it was missing 2 nuts and bolts for the front shock extenders. handles just fine with a trailer. The heaviest i've towed was a 3K lb Bri-Mar Dump trailer with a bobcat in it, roughly 10K total. The tires were the biggest thing holding me back. i recently towed the same trailer with about 4K lbs of household stuff, totaling about 7K lbs and it did much better. Not sure how heavy your loads are. if they are over 7K total, i would stick with 35's. the 37's will drastically decrease your mileage, but they look damn good IMO. on a good day, i can see 15mpg on the highway, with a tailwind, slightly downhill, and keeping it under 65. good mileage, 6.4's and 37" tires do not belong in the same sentence. most of my driving is mixed city and hwy, and i usually average around 12.5-13.5 mpg unless i'm plowing or towing, then i'm around 10mpg. These are hand calculated and speedometer adjusted with Livewire and confirmed accuracy with 2 different GPS devices. gotta pay to play!
Next set for me will be the Nitto 37x12.5x20. wont be until summer 2015 tho. This set is still going strong and i have ~30K on them so far, rotating every 10K.
Kris
post #5 of 10 Old 03-11-2014, 10:29 AM Thread Starter
Did you go with any special shocks with that kit? Or just use the factory with the extensions?
S&B intake
boost fooler
TW 6 position chip
8 inch lift
post #6 of 10 Old 03-11-2014, 10:48 AM
Raul@Stealth Automotive's Avatar
i would just go with a leveling kit. i would go with a quality kit like the readylift or you can go a lil bit better and go with a carli or Icon kit....
Raul@Stealth Automotive is offline
post #7 of 10 Old 03-11-2014, 02:55 PM
06superduty3997's Avatar
I had just went with a 2.5 leveling kit on my 350, still debating if I should go with the 3.5
2008 F-350 FX4 CCLB 6.4 Powerstroke
SCT Livewire With RCD Tunes. Magnaflow 5" Straight Pipe Exhaust with an 6 inch tip
Airaid drop in filter with a modded stock box. Halo/LED headlights, LED Mirror, Dually Fender Lights.
2.5 leveling kit Soon to Come,
Road Armor Front Bumper with Pre Runner Bar.
AF 19.5 wheels black
LED D2s and light bar
06superduty3997 is offline
post #8 of 10 Old 03-11-2014, 07:09 PM
Quoted: 2 Post(s)
when i did the leveling kit, i just used the extensions, but later upgraded to some blistein 5100's and took the extensions out.
Kris
post #9 of 10 Old 03-12-2014, 09:28 AM Thread Starter
Do you have any pictures of the 2.5?
S&B intake
boost fooler
TW 6 position chip
8 inch lift
post #10 of 10 Old 03-26-2014, 08:28 PM
I'm considering the bilstein level thats 2.25 i think. its the 5100 shocks and a 5" rear block. I was quoted 785 for the shocks, front springs, and rear block.
Qtrung606 is offline
