Need help with 2008+ mirror housing p/n - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-17-2014, 04:34 PM Thread Starter
I've been looking for the lower back cover/housing of the mirror assy and I can't seem to find out the part number or if it's even possible to order it. It's shown as being removeable (with screws) in the attached diagram.
sfoltz is offline
post #2 of 8 Old 02-19-2014, 07:07 AM
I could be wrong but I believe you have to buy the whole mirror assembly.
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #3 of 8 Old 02-19-2014, 08:06 AM Thread Starter
That's what I figure too. I'm looking on eBay for a mirror to use as parts.
sfoltz is offline
post #4 of 8 Old 02-19-2014, 08:22 AM
If you decide to replace the mirror all together go OEM. I put aftermarket 08+ mirrors on my 06 and after about a month they started to rattle. I've talked to others that had the same issue. Seems they just don't hold up. With only needing the lower housing you may be fine.. I just don't know that I would risk it. Even though an OEM mirror assembly was 1,200 when I checked it's worth it in my opinion if you can spare that kind of coin for it. I need to replace both of mine as the plastic gears for the power fold and extend have apparently been worn out. But for now I'll just do it by hand
2010 F250 CCSB
06psd6.0 is offline
post #5 of 8 Old 02-20-2014, 01:37 AM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
They're $800/pair for power mirrors with the folding, telescoping, memory, turn signal/marker light, and heated mirror function. These are with the black covers, not the painted ones. For a set of primed covers, it's an additional $130. If you want chrome covers, it's an extra $250.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #6 of 8 Old 02-20-2014, 07:01 AM
Is that for factory ford mirrors? And where?
2010 F250 CCSB
06psd6.0 is offline
post #7 of 8 Old 02-20-2014, 10:16 AM
Quoted: 19 Post(s)
Yes. Factory, OEM mirrors. They're from Sunrise Ford. They're a site sponsor. I've ordered a few thing from them. Never had an issue. I even have a promo code for an additional 5% off. Just type EXTRA5 in the promo code box. Doesn't say when it expires though.
Their part diagram lists an actuator. Not sure what that actuator is for. Might be worth a call to them to see if that's an actuator for the folding mechanism.
This is the link to their site. Click here.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #8 of 8 Old 02-20-2014, 12:22 PM
I'll have to check that out when I get a chance. Thanks for the info!
2010 F250 CCSB
06psd6.0 is offline
